Filling the scene with "Fake" characters
Hi guys, im actually making a scene who need a lot a people (a classroom), i would like to add something like totally black character you know like stick man but realistic, how can i do that ? Or if you have suggestion for better idea im all ears !
Thank you and have a great day :)
  • HylasHylas Posts: 5,328
    Lorenzo & Loretta a currently available for 4$ if you put them in the cart with any New or Still New release.
    https://www.daz3d.com/lorenzo-and-loretta-bundle
  • onixonix Posts: 282
    Unless you deliberately want those characters to look like mannequins or ghosts.  I think a way better idea is to use copies of the same character and instances. to save more memory use the same textures from the main character.
    Genesis 8 figure is an extremely low poly model so they use very little geometry memory clothes are way more expensive in terms of memory and geometry as some simple dress may have more polygons that genesis 8 figure while one decent hair will use more than 10 figures. to avoid that I would recommend using some older hair models from victoria 4 time and avoid long hair or anything complex
    I made scenes with more than 16 figures in them.  and the only problem is waiting until they will get duplicated. but you can duplicate one figure then duplicate those 2 at once and get 4 then duplicate 4 and get 8  and so on.
    If all characters in your classroom use the same uniform there will be no problem adding like 10 copies of them and then you can also make multiple instances of each copy which will be enough for the entire graduation ceremony also you can combine instances of hair with instances of characters. then slightly change the size of your characters and a direction.
  • Here are some lo-res figures with a basic dark gray texture. Is this the sort of effect you're looking for?
    813 x 944 - 665K
  • MarcCCTxMarcCCTx Posts: 947
    edited January 2021
    Or do you want really low res... https://www.daz3d.com/stickman
    Or the Stylized business people from https://www.daz3d.com/3d-starter-pack
    Post edited by MarcCCTx on
