Can't scale viewport
juanjoharo
I've switched to a 41" monitor at 3840x2160 res and i'm unable tio scale the viewport to take advantage of all that screen res. In the video you can see how is acting weird... is there any way to solve this? Thanks
What is your GPU? If you have more than one, especially if one is on the CPU, which is DS using?
I have only a Geforce GTX 960 4Gb, just this one... my previous monitor was 32" and never had this issue. In full screen mode hapens this. Is like the viewport has some limitations in resolution
Done! Make pane undokable, thet appears the windows borders and can maximize! Thanks for comment :)
Nop, i did not work... after doing what i tell you and close and open Daz it stops working,¡,,, i can't use my two monitor and that is a step back, i can't figure why DS can't adapt to higher resolutions
