How do I change where Daz3D 4.14 saves?
zombiedog
Hello,
I am having the hardest time with getting Daz3D to move where it saves my library and then to get Daz3D to see it.
Does anyone have a step by step walk through? I tried YouTube, but it is from the old version.
Thank you
What do you mean, that you are trying to change the location of your content libraries in Daz Studio?
Yes, sorry for being unclear.
It seems like it should be so streight forward, but I just can not get it to work.
You can add a content location to DS from the Content Library pane, by right-click on Daz Studio Formats (or one of the other formats headings for that type of file) and selecting the Add New Base Directory. You can remove an existing diectory by right-click on the top-level name under Daz Studio Formats. In all cases you want the folder that contains the Data and Runtime folders.
Thank you for that advise. I managed to get the content that I have already saved to the new drive to be seen by Daz3D.
Now how do I get my new content that downloads from the DazCentral to save to a different drive?
Daz Central allows only the setting of a base path, from which all others are derived. If you want to set paths individually then use Install Manager https://www.daz3d.com/get_install_manager/
