Missing Smart Content
brainmuffin
I am missing many pieces of content in the Smart Content area, in particular none of the human characters under figures. Is there a way to had Studio rescan and pull in all the content?
Go to the drop-down menu in the Content Library pane, select Content DB Maintenance, and then select 'Re-Import Metadata'.
Well, that sorta worked. Nothing shows up in the menus past Gen 4, but some of the other content does show under all. I also converted old database content.
Are you sure that you have the library correctly entered in the Content Directory Manager for DAZ Studio and Poser Formats.
Edit > Preferences > Content Library > Content Directory Manager.
All Genesis content (and later) should appear in Smart Content. I don't know what is wrong, but it may be something up with the DB files themselves. Are you still using Valentina/CMS, or did you install PostgreSQL?
This happened to me this morning as well. I did what JimmyC suggests above and everything came back.
I had to do a "reset" followed by "reimport metadata". That worked.
