Bryce side by side config
My Bryce won't launch. I get an error about faield to start its side by side configuration is incorrect. How can I fix this.
Thanks.
    The main fox for this is to go to Microsoft http://support.microsoft.com/kb/948854 and download the distributble that you will find on this page http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=26347
    THe reason you are getting the error is that Bryce is a 32bit application, and you are missing a .dll in the VisualC++ on your PC.
    You need the X86 version of the download.
  • edited December 1969
    Thanks. I run 64 bit. Noticed Bryce was only 32.
  • frank0314frank0314 Posts: 15,094
    It will still run fine on your 64 bit system.
  • CoyoteIBCoyoteIB Posts: 2
    I get the side by side config error also... I went to MS and downloaded the file at the address you gave.. vcredist_x64.exe. Installed it and rebooted... still the same error/problem (side by side) stopping it from loading up.. any other ideas ?
    Thanks in advance :)
    You need to downloand the You X86 version of the download.
    Your right !! doh !! I took my stupid pill the other day :) working fine now Thanks again !!
    You're welcome. No probs, when I do things like that I blame it on a senior moment
