Octane panel issue
Octane was interesting while it lasted, but I accidently pushed the node editor pane off screen and I couldn't close the panel. I managed to close Studio hoping restarting the program might reset it. Now the editor panel opens with Daz crashing Studio. Any ideas to fix this, I don't mind uninstalling the Octane plug-in if needed.
You could try removing
%AppData%/daz 3d/studio4/layout.dsx
which should reset the location and open/closed status of the Octane pane (unless it has some kind of local override).
Richard,
Will this -
You could try removing%AppData%/daz 3d/studio4/layout.dsx
Cause me to loss my current Workspace configuration?
Yes, I'm afraid it will - though if you had saved it you should be able to reload it.
On the plugin side you can try the following:
1) Go to the plugins list, deactivate Octane Plugin, restart Daz. Reactivate Octane plugin.
2) Try deleting C:\Users\[username]\OctaneRender\Data\OctaneRender_settings.oczdb (Daz needs to be closed to allow) which will reset Octane settings to default.
You could also switch temporarily to a different layout and switch back. It's always a good idea to have the layout you use frequently saved in its working state so you can reload it as needed if things go sideways.
V.
So I deleted OctaneRender_settings.oczdb and did an uninstall and restall and that fixed the issue. Thank you for the information.
