tgunner's tutorial for fitting V4 clothing to Genesis
srieschsriesch Posts: 4,243
I just tried this Tutorial for Fitting Loose V4 Clothing to Gn/G2F in DS by tgunner http://tgunner.deviantart.com/art/Fitting-Loose-V4-Clothing-to-Gn-G2F-in-DS-415265231 . I'm having no luck, hopefully somebody can tell me what I'm doing wrong, and/or provide insight on a few questions that popped up while I was trying.
I decided to attempt the tutorial using "Moroccan Dreams for Victoria 4"'s V4MrDUDress.cr2 . (The tutorial says "General > Actors > Female" but since that doesn't exist, I guessed it meant "Genesis > Actor > Female", and similarly I selected "Show Hidden Properties" from the Parameters pane menu rather than "Show Hidden Items".)
Question 1: At the "Adjust the Fit" section of the tutorial, what I end up with is the screenshot below. So... did I do something wrong, or is the pokethrough and sleeves that are too low I'm seeing really what I get and will need to adjust, and I actually accomplished the fit the tutorial is trying to do?
Question 2: At this point, the dress is autofit to Genesis. I now save it as a scene subset. I delete it. I reload it from the saved file, at which point it is no longer fit to anything. In the Parameters pane I change "fit to" to Genesis, and now it looks like this second screenshot. If not already answered or caused by problems addressed by the previous question, how am I supposed to fit it if not via the "fit to" parameter?
Question 3: Just to make sure I wasn't doing anything wrong, I followed the exact tutorial step of using Genesis, but I would really want the clothing to fit to V5. Must I use V5 instead of Genesis when following the tutorial, or must use Genesis and cannot use V5 when creating the new fit and only fit it to V5 later, or something else? I'm parroting instructions here, I don't actually know what's going on in the background so this might be a silly/obvious question and answer for you.
468 x 546 - 137K
474 x 543 - 140K
