Silly question coming from me, but...
SnowSultan
in The Commons
Does anyone happen to have any clean (as in not JPG) texture templates for the G8 figures? I tried to make some using my very old UV Mapper Classic and either I'm doing something wrong (which is likely), or something changed since I last made seam guides because they're all screwy and don't line up with each other. I also tried applying some old G3 templates to it and they don't fit either (huh, I thought they were compatible, that's the whole reason why I never made G8 seam guides?). Anyway, I just need blank ones, as large as possible up to 4k and for the base figure(s). If you can't post them anywhere, let me know and I'll send you a direct email address. Thank you very much in advance.
probably doesn't support UDIM
export obj UV tiles collapsed checked
Not as .jpgs umm could I save them out as .pngs for you?
PNGs or even GIFs would be fine, I just want to avoid artifacts because it makes it more difficult to fill them in if necessary. Thank you very much.
I'll try that Wendy, thought I did already but I could have overlooked it.
I apologize, I was able to get the settings right and am making the templates myself now. Thank you very much for the offer to help.
just in case I wasn't clear these are pngs that I had resaved from jpgs ...... it's just what I have .. but I put them in zip files
well that'll teach me to refresh won't it ,lol ,ummm just in case you forgot ,male and female are different UVs did that make sense? Anyway looking forward to seam guides!!
Ah, sorry for any misunderstanding! Also, I won't actually be making G8 seam guides (DAZ has said it's unnecessary because of G3 compatibility and the wider use of 3D painting programs), I'm making drawing guides for using the figures for 2D art. I'll try to share them if they turn out well enough though.
Oh okay still looking forward to see what you do .....
