G3F Texture on G8F preview
3dOutlaw3dOutlaw Posts: 2,481
I am working on a G8F version of my G3F character, but when I apply the G3F textures to G8F, I get this glowy cartoony preview, versus the normal preview.
If I copy paste the same texture from G3F it works without this glowy thing going on...but I dont think I can do that with eyes and such, and I want the option to change makeup wihtout having to load G3F every time.
Any thoughts on why that occurs?
    Richard, can you move this to the technical help forum?
  • Done. How are you applying the textures? If the shader is different then Copy/Paste won't update it, just settings with the same name.
    Moved the thread - you can do that yourself by editing the first post and clicking the forum name above the title, which will open a drop down list of available forums
  • LeanaLeana Posts: 13,326
    You can move it yourself by editing the first post.
    OK, thanks I missed that.
    For the process:
    1. Find the G3F Mats in the content library and double click them to apply to G8F = Glowy skin on left
      versus...
    2. Find the same G3F Mats in the content library, apply them to G3F, then click G3F Skin, Copy, click G8F, Paste = Skin looks good, like on the right.
    I have never had a problem applying G3F mats to G8F, but a lot of G3F figures had both, 3DL and Iray materials and applying one on a surface that's already using the other, doesn't always work the way it should.
    edited December 2020
    OK, I did some testing (tried a lot of shaders) and it seems it was a problem with that shader in particular, and lo and behold, I noticed an "Updated Iray Shaders" folder in there, which then worked as expected.  My bad, seems it was a shader specific problem and a fix already exists.  It was for Fredel's retro heroine btw, in case anyone stumbles across this, or searches for it.  Thanks for the replies!
    Post edited by 3dOutlaw on
