completely removing Genesis 8 Males belly button.
5200north
in The Commons
what is the easiest way to remove the belly button.
i'm working on a character that woudn't be born the traditonal way and i just realized he shouldn't have a hint of a belly button to look right.
i zeroed out all morphs associated with the belly button. i should probably be opening up photoshop next, right?
thanks everyone
(hope this makes sense, my dog is pulling at me to go out as i type this....)
4032 x 3024 - 3M
Yes. Any textures that would indicate a belly button(base, trans, glossy, bump, normals, etc.) would need to be edited.
If it isn't a texture problem, you could try unchecking the parameter limits and set it to less than zero.
i thought that would be the answer. thanks.
In Photoshop it's "Click!" you be done.
