Strange Shading with DAZ Studio 4.6
Hi,
I'm hoping someone can help me. Since upgrading to DAZ studio 4.6 I've noticed that my Victoria 6 character appears with this strange, white, blown out shading when viewed in the smooth shaded mode.
Like this:
https://dl.dropboxusercontent.com/u/38398338/DAZ/DAZ_Error.jpg
Yet, It looks fine in textured mode... like this...
https://dl.dropboxusercontent.com/u/38398338/DAZ/DAZ_Error2.jpg
I really want to be able to view this character in smooth shaded mode with a normal, gray phong shader applied... does any one know why it is displaying with this white, blown out, material?
More importantly does anyone know how I can fix this?
Thanks!
Cheers,
J
    Reduce SSS to 0% for the skin surfaces.
  • Richard HaseltineRichard Haseltine Posts: 112,087
    That's a shader error - do you have the Default Lights and Shaders installed? Depending on which version you upgraded from you may not have had the lights and shaders in a separate zip previously. If you do have the lights and shaders installed try restarting DS.
  • edited December 1969
    Hi Richard,
    I previously had v4.5 installed, which did not exhibit this behavior. All I did was install 4.6, I did not change anything. I've tried restarting DS several times but I'm still seeing this.
    Cheers,
    J
    Just to follow up... yes, this does appear to be some sort of shader error.... except:
    Have a look at this:
    https://dl.dropboxusercontent.com/u/38398338/DAZ/DazError3.jpg
    Here you can see that the default Genesis character on left is shading as expected, whereas the Victoria 6 on right is showing the strange white shading.
    I uninstalled everything and did a re-install, default lights and shaders are installed and I've rebooted several times... no change.
    I attempted to adjust the SSS settings as was suggested by jestmart but I'm new to using DAZ studio and I'm not exactly sure which parameter needs adjustment... there are a lot of them :-)
    Any suggestions and or guidance would be appreciated.
    Cheers,
    J
