PoserCF files...Needed?
ScavengerScavenger Posts: 2,674
A search didn't turn up anything....
Do I need the PoserCF files installed? I don't plan on using Poser, and while they are small in file size, i could see them building up in.
    If you are only using DAZ Studio, you do not need Poser Companion Files (PoserCF)
    If you are using DIM (DAZ Install Manager), you can set a filter so that you only download the files that you need.
  • srieschsriesch Posts: 4,243
    I don't have any examples to point at, but thought that at some point in the past I did find some things that were only in the Poser format and not in the corresponding matching DS format. Similarly, there might be older obsolete DAZ Studio formats that don't work in newer versions where you might need the Poser files, although perhaps that was a temporary thing that will be or already has been fixed with product updates?
  • fixmypcmikefixmypcmike Posts: 19,709
    If they're PoserCF's (as opposed to Poser versions, and as opposed to StudioCF's) you don't need them in DS.
