Wishlist issue
I try to add an item to my wishlist, however it says I must first login.  However, I am logged in.  Anyone else having this issue?  Or is it borked at the moment?
  • GordigGordig Posts: 10,844
    Click on the account icon on the sales page. If the login dialog pops up, log in there.
  • jcleaver42jcleaver42 Posts: 10
    edited December 2020
    Thanks, but that is where I had logged in.  No login prompt appears when clicking the account icon.
    I did try logging out, and then logging back in. Did not fix the issue. I can see my current wishlist, just can't add anything to it.
    Post edited by jcleaver42 on
  • As a workaround you could put the item in your cart and move it to your wishlist from there.
  • Thanks!  That worked.  Not sure why it doesn't work the normal way, but at least there is a way!
  • ByrdieByrdie Posts: 1,783
    Got the same problem here, couldn't add to my wishlist without logging in while I was already logged in. So I tried logging in like it said, only to be looped back to the same page with the same message. Moving it from the cart to the wishlist seems to be the only option for now. Using latest Chrome browswer on Win7 Pro if that helps.
  • AtiAti Posts: 9,208
    Reloading the page and trying again, until it eventually works, is another way to go. Adding to the cart, then to wishlist might be faster, though.
  • This issue is discussed in the Store Issues thread https://www.daz3d.com/forums/discussion/447446/store-issues-known-problems-please-read#latest and elsewhere so I am closing this thread.
