Can a render be continued for more Iterations/Samples
Recenty I did a render and after completions I felt with more iterations or samples I could have got a better result. So is there a way to continue last render such that Daz would proces it further or the only option is to increse Iterations and restart the render.
I am reffering to an Image render not multiple renders.
  • prixatprixat Posts: 1,627
    Yes there is.
    Slide open the side menu in the render window. (It's a tiny arrow on the left.)
    Check which 'stop condition' stopped your render and increase it's value. That should make the 'Resume' button active again.
    You can 'Resume' as many times as you like with any of the four 'stop conditions'.
