LAMH hair not following pose changes
sriesch
When using LAMH, the hair preset does not always follow posing changes. What is the correct way to pose figures with LAMH hair, and/or are there any fixes or workarounds I should be using? In this example, I'm using DS 4.8, and the figure is the cat world regenesis jaguar. I've seen two issues:
1. Applying a presaved pose doesn't work at all. The figure poses,but the hair remains in the T pose (see screenshot below).
2. Manually posing works some of the time with the hair following the pose change, but other times it does not. For example I was able to move the figure's arms around and bend the fingers, but twisting the hand left the hair behind.
Also, I unfortunately have issues saving the files and sometimes applying the preset, so (when possible) I have to save the scene then load the LAMH as the last step before rendering and exit without saving the LAMH preset and repeat later if changes are made. If that's not possible (such as with .duf content that has the figure and hair preset connected so the preset can't be loaded last) I have to complete the entire project and render in a single session and cannot save any of my work for future use. If anybody else has experienced this, are there any workarounds that you have found? (Not trying to bash the plugin, trying to get more effective use out of it.)
Thanks for any suggestions!
