Solved : Iray preview keeps restarting : updating geometry
I recently, and for no apparent reason, the Iray preview keeps restaring after a few iterations and, therefore, never finishes. The main Iray renderer works fine, however.
The log just says "updating geometry" and "updating motion transforms" when this is happening.
Does anyone have any ideas? At least point me at a cetain direction to troubleshoot this.
Here's the relevant portion of the log:
2020-12-12 23:54:33.394 Iray [INFO] - POST:RENDER :: 1.0 POST rend info : Postprocessing denoiser is enabled
2020-12-12 23:54:33.394 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry.
2020-12-12 23:54:33.420 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating motion transforms.
2020-12-12 23:54:33.420 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph.
2020-12-12 23:54:33.420 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 0
2020-12-12 23:54:35.214 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (1 triangle object with 5567k triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 5567k triangles, 0 fiber instances yielding 0 segments) took 1.794s
2020-12-12 23:54:35.238 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials.
2020-12-12 23:54:35.675 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 14521 textures, 0 lambdas (0 unique)
2020-12-12 23:54:35.936 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Emitter geometry import (74 light sources with 22920 triangles, 1 instance) took 0.001s
2020-12-12 23:54:35.938 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment.
2020-12-12 23:54:36.055 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate.
2020-12-12 23:54:36.063 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lens.
2020-12-12 23:54:36.063 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights.
2020-12-12 23:54:36.063 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags.
2020-12-12 23:54:36.066 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating caustic portals.
2020-12-12 23:54:36.066 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals.
2020-12-12 23:54:36.068 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using iray core convergence estimate.
2020-12-12 23:54:36.074 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer
2020-12-12 23:54:36.074 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using interactive scheduling, caustic sampler disabled
2020-12-12 23:54:36.074 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing local rendering.
2020-12-12 23:54:36.075 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing OptiX Prime for CUDA device 0
2020-12-12 23:54:36.080 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 1 device(s):
2020-12-12 23:54:36.085 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1070)
2020-12-12 23:54:36.085 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2020-12-12 23:54:36.085 Iray [INFO] - IRAY:RENDER :: 1.8 IRAY rend progr: CUDA device 0 (GeForce GTX 1070): Processing scene...
2020-12-12 23:54:36.130 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Geometry memory consumption: 199.143 MiB (device 0), 0.000 B (host)
2020-12-12 23:54:53.147 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Texture memory consumption: 2.034 GiB for 160 bitmaps (device 0)
2020-12-12 23:54:53.153 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : Importing lights for motion time 0
2020-12-12 23:54:53.154 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : Initializing light hierarchy.
2020-12-12 23:54:53.523 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : Light hierarchy initialization took 0.369s
2020-12-12 23:54:53.525 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Lights memory consumption: 3.880 MiB (device 0)
2020-12-12 23:54:53.546 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Material measurement memory consumption: 0.000 B (GPU)
2020-12-12 23:54:53.552 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Materials memory consumption: 6.236 MiB (GPU)
2020-12-12 23:54:53.713 Iray [INFO] - IRAY:RENDER :: 1.8 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 17.627s
2020-12-12 23:54:53.713 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 559.594 KiB for frame buffer
2020-12-12 23:54:53.715 Iray [INFO] - IRAY:RENDER :: 1.8 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
2020-12-12 23:54:53.774 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00001 iterations after 17.686s.
2020-12-12 23:54:53.776 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2020-12-12 23:54:53.916 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00003 iterations after 17.825s.
2020-12-12 23:54:54.032 Iray [INFO] - IRAY:RENDER :: 1.8 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.688 GiB of work space (2048k active samples in 0.052s)
2020-12-12 23:54:54.037 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00007 iterations after 17.944s.
2020-12-12 23:54:54.573 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00015 iterations after 18.163s.
2020-12-12 23:54:54.643 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry.
2020-12-12 23:54:54.659 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating motion transforms.
2020-12-12 23:54:54.659 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph.
2020-12-12 23:54:54.664 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 0
2020-12-12 23:54:55.747 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (1 triangle object with 5567k triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 5567k triangles, 0 fiber instances yielding 0 segments) took 1.083s
2020-12-12 23:54:55.747 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials.
2020-12-12 23:54:56.309 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 14521 textures, 0 lambdas (0 unique)
2020-12-12 23:54:56.692 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Emitter geometry import (74 light sources with 22920 triangles, 1 instance) took 0.001s
2020-12-12 23:54:56.730 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights.
2020-12-12 23:54:56.731 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags.
2020-12-12 23:54:56.734 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating caustic portals.
2020-12-12 23:54:56.734 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals.
2020-12-12 23:54:56.743 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer
2020-12-12 23:54:56.743 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using interactive scheduling, caustic sampler disabled
2020-12-12 23:54:56.749 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing OptiX Prime for CUDA device 0
2020-12-12 23:54:56.756 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 1 device(s):
2020-12-12 23:54:56.756 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1070)
2020-12-12 23:54:56.761 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2020-12-12 23:54:56.761 Iray [INFO] - IRAY:RENDER :: 1.8 IRAY rend progr: CUDA device 0 (GeForce GTX 1070): Processing scene...
2020-12-12 23:54:56.794 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Geometry memory consumption: 199.143 MiB (device 0), 0.000 B (host)
2020-12-12 23:54:57.035 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Texture memory consumption: 2.034 GiB for 160 bitmaps (device 0)
2020-12-12 23:54:57.040 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : Importing lights for motion time 0
2020-12-12 23:54:57.040 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : Initializing light hierarchy.
2020-12-12 23:54:57.412 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : Light hierarchy initialization took 0.371s
2020-12-12 23:54:57.414 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Lights memory consumption: 3.880 MiB (device 0)
2020-12-12 23:54:57.436 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Material measurement memory consumption: 0.000 B (GPU)
2020-12-12 23:54:57.443 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Materials memory consumption: 6.236 MiB (GPU)
2020-12-12 23:54:57.465 Iray [INFO] - IRAY:RENDER :: 1.8 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 0.704s
2020-12-12 23:54:57.465 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 559.594 KiB for frame buffer
2020-12-12 23:54:57.466 Iray [INFO] - IRAY:RENDER :: 1.8 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
2020-12-12 23:54:57.509 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00001 iterations after 0.745s.
2020-12-12 23:54:57.510 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2020-12-12 23:54:57.642 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00003 iterations after 0.876s.
2020-12-12 23:54:57.745 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00005 iterations after 0.979s.
2020-12-12 23:54:57.886 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00008 iterations after 1.120s.
2020-12-12 23:54:58.021 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00013 iterations after 1.255s.
2020-12-12 23:54:58.252 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00018 iterations after 1.486s.
2020-12-12 23:54:58.318 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00023 iterations after 1.552s.
2020-12-12 23:54:58.378 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry.
2020-12-12 23:54:58.402 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating motion transforms.
2020-12-12 23:54:58.407 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph.
2020-12-12 23:54:58.407 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 0
2020-12-12 23:54:59.586 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (1 triangle object with 5567k triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 5567k triangles, 0 fiber instances yielding 0 segments) took 1.179s
2020-12-12 23:54:59.586 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials.
2020-12-12 23:55:00.113 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 14521 textures, 0 lambdas (0 unique)
2020-12-12 23:55:00.470 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Emitter geometry import (74 light sources with 22920 triangles, 1 instance) took 0.002s
2020-12-12 23:55:00.515 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights.
2020-12-12 23:55:00.517 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags.
2020-12-12 23:55:00.519 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating caustic portals.
2020-12-12 23:55:00.524 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals.
2020-12-12 23:55:00.530 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer
2020-12-12 23:55:00.530 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using interactive scheduling, caustic sampler disabled
2020-12-12 23:55:00.536 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing OptiX Prime for CUDA device 0
2020-12-12 23:55:00.543 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 1 device(s):
2020-12-12 23:55:00.548 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1070)
2020-12-12 23:55:00.548 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2020-12-12 23:55:00.548 Iray [INFO] - IRAY:RENDER :: 1.8 IRAY rend progr: CUDA device 0 (GeForce GTX 1070): Processing scene...
2020-12-12 23:55:00.583 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Geometry memory consumption: 199.143 MiB (device 0), 0.000 B (host)
2020-12-12 23:55:00.814 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Texture memory consumption: 2.034 GiB for 160 bitmaps (device 0)
2020-12-12 23:55:00.819 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : Importing lights for motion time 0
2020-12-12 23:55:00.820 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : Initializing light hierarchy.
2020-12-12 23:55:01.205 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : Light hierarchy initialization took 0.385s
2020-12-12 23:55:01.207 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Lights memory consumption: 3.880 MiB (device 0)
2020-12-12 23:55:01.226 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Material measurement memory consumption: 0.000 B (GPU)
2020-12-12 23:55:01.233 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Materials memory consumption: 6.236 MiB (GPU)
2020-12-12 23:55:01.259 Iray [INFO] - IRAY:RENDER :: 1.8 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 0.711s
2020-12-12 23:55:01.259 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 559.594 KiB for frame buffer
2020-12-12 23:55:01.261 Iray [INFO] - IRAY:RENDER :: 1.8 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
2020-12-12 23:55:01.307 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00001 iterations after 0.755s.
2020-12-12 23:55:01.308 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2020-12-12 23:55:01.451 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00003 iterations after 0.898s.
2020-12-12 23:55:01.523 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00005 iterations after 0.969s.
2020-12-12 23:55:01.631 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00007 iterations after 1.078s.
2020-12-12 23:55:01.736 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00011 iterations after 1.183s.
2020-12-12 23:55:01.988 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend progr: Received update to 00016 iterations after 1.435s.
2020-12-12 23:55:02.044 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry.
2020-12-12 23:55:02.068 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating motion transforms.
2020-12-12 23:55:02.069 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph.
2020-12-12 23:55:02.074 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 0
2020-12-12 23:55:03.114 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (1 triangle object with 5567k triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 5567k triangles, 0 fiber instances yielding 0 segments) took 1.040s
2020-12-12 23:55:03.114 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials.
2020-12-12 23:55:03.630 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 14521 textures, 0 lambdas (0 unique)
2020-12-12 23:55:04.004 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Emitter geometry import (74 light sources with 22920 triangles, 1 instance) took 0.001s
2020-12-12 23:55:04.047 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights.
2020-12-12 23:55:04.048 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags.
2020-12-12 23:55:04.051 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating caustic portals.
2020-12-12 23:55:04.051 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals.
2020-12-12 23:55:04.058 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer
2020-12-12 23:55:04.058 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using interactive scheduling, caustic sampler disabled
2020-12-12 23:55:04.064 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing OptiX Prime for CUDA device 0
2020-12-12 23:55:04.070 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 1 device(s):
2020-12-12 23:55:04.070 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1070)
2020-12-12 23:55:04.075 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
Post edited by Antono on
Nevermind, I figured it out. Two characters with the same type of item fitted to them. One character made invisible (click on the little eye icon) but the item fitted to it was visible. It seems the item tried to follow the visible character's morphs.
Anyway, if I restore visibility to the items everything works fine.
