daz Studio turns itself off
Hi
I have another problem with daz 4.12, when I run daz, after a few seconds, it closes itself. No bug or errors, same think is with 4.14.
Everything was fine yesterday, today was only one critical crush and now daz wont start ( ofc start , but it close itsalfe after ....10 seconds)
p.s sorry for my horrible english
logs (or part of it)
2020-12-12 18:31:55.295 NVIDIA Iray GPUs:
2020-12-12 18:31:55.295 GPU: 1 - GeForce GTX 1050 Ti
2020-12-12 18:31:55.295 Memory Size: 3.9 GB
2020-12-12 18:31:55.295 Clock Rate: 1392000 kHz
2020-12-12 18:31:55.295 Multi Processor Count: 6
2020-12-12 18:31:55.295 CUDA Device ID: 0
2020-12-12 18:31:55.295 CUDA Compute Capability: 6.1
2020-12-12 18:31:55.295 PCI Bus ID: 1
2020-12-12 18:31:55.295 PCI Device ID: 0
2020-12-12 18:31:55.300 TCC Mode: disabled
2020-12-12 18:31:55.300 Display: attached
2020-12-12 18:31:55.300 NVIDIA Iray Scheduling Configuration:
2020-12-12 18:31:55.300 CPU Load Limit: 4
2020-12-12 18:31:55.300 CPU Thread Affinity: disabled
2020-12-12 18:31:55.300 GPU Load Limit: 1
2020-12-12 18:31:55.556 Total class factories: 2082
2020-12-12 18:31:55.557 Creating Script Engine...
2020-12-12 18:31:55.582 WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
2020-12-12 18:31:55.583 3D mouse support library could not be loaded.
2020-12-12 18:31:55.589 Creating Main Window...
2020-12-12 18:31:55.590 Creating Viewport Manager...
2020-12-12 18:31:55.624 Successfully created OpenGL viewport for Viewport1.
2020-12-12 18:31:55.723 Successfully created OpenGL viewport for Viewport2.
2020-12-12 18:31:55.790 Successfully created OpenGL viewport for Viewport3.
2020-12-12 18:31:55.856 Successfully created OpenGL viewport for Viewport4.
2020-12-12 18:31:55.923 Creating Action Manager...
2020-12-12 18:31:55.934 Creating Pane Manager...
2020-12-12 18:31:56.056 Successfully created OpenGL viewport for AuxViewportView.
2020-12-12 18:31:56.935 WARNING: QMetaObject::connectSlotsByName: No matching signal for on_pslJpegSaveQuality_valueChanged(int)
2020-12-12 18:31:56.940 WARNING: QMetaObject::connectSlotsByName: No matching signal for on_sldAniImageQuality_valueChanged(int)
2020-12-12 18:31:56.941 WARNING: QMetaObject::connectSlotsByName: No matching signal for on_bbnRestartDriver_released()
2020-12-12 18:31:57.040 WARNING: QMetaObject::connectSlotsByName: No matching signal for on_ptbEditNodeGraph_released()
2020-12-12 18:31:58.475 Executing startup script...
If it crashed one possibility is that a configuration file was corrupted - go to
%AppData%/daz 3d/studio4/
(just paste that into a File Explorer window's address bar) and remove the layout.dsx, then try starting DS again - does it open now?
Unfortunately it does not work, the program continues to shut down after a few seconds ;(
I don't believe I found a solution,
Earlier I uninstalled octane render (I don't use it), and something must have broken, when I reinstalled it, everything was back to normal, daz work perfectly .
I'm glad everything is back to normal but I still don't understand why daz didn't work without octane render
