Iray shaders not working
For some reason my Iray shaders are not working anymore. I load my figure, bring up my shaders in my content library, Use the surface edit tool, select the shader I wish to apply, and then click on the figure I wish to change. This always worked in the past but for somereson today it is not. Any thoughts?
Have you checked that the right surface is selected in the Edito tab of the Surfaces pane? And are you double-clicking the shader after selecting the surface? It sounds as if you are double-clicking the shader, then selecting the surface, which won't work.
