Cityscapes Backdrops 'Cannot Open'
Hi, bought this a while back in the sales and it would refuse to work. Uninstalled and just tried it again today with no luck. It's this pack here: https://www.daz3d.com/cityscapes-backdrops
If I try to use it in Daz, it comes back saying it cannot be opened because an error occured. Any help? :) Thank you.
  • GreybroGreybro Posts: 2,707
    You must have a corrupt install. It worked for me just now. Trying installing it manually.
    1051 x 678 - 253K
    CityScapse
  • Came across this in a Google search as I was having the same issue. I eventually was able to do it through an install via DazCentral but it took multiple attempts, including with DIM and inside Studio. The log said something about an incorrect syntax.
    2021-04-02 11:57:58.443 C:/Users/[USER]/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_29331/props/cityscapes/cs02 curved medium.duf (1,1): Syntax error - expected '{' or '['
  • Richard HaseltineRichard Haseltine Posts: 111,721
    If you initially installed through DS itself that is most likely a file that did not decrypt after download.
  • gloam3dgloam3d Posts: 200
    Hi all. I forgot about this product but now I need to use it. It does not work despite multiple fresh installs, an updated Daz studio, and simply says the file does not exist no matter which backdrop I click.
    1240 x 644 - 275K
  • SevrinSevrin Posts: 6,314
    How did you install it?  Does it work if you try from the Content Library?
    I installed with DIM a long time ago and have never had trouble with it, so it sounds like an install issue.
    Hi Sevrin, I have tried installing through Daz Central.
    Whether DIM or Central doesn't matter if they are not configured to install to a proper library Studio knows.  Smart Content will gleefully show content that is not installed properly because it is a databased system.  As Sevrin asked can you see and load the file from Content Library pane?
