V6/G2 in poser
DimeolasDimeolas Posts: 192
Poser10, have dson installed...I can load Genesis just fine but...when I try and load V6 or G2male it will act like dson has worked and its loaded, but is nowhere to be foiund in scene.
Any ideas?
  • Richard HaseltineRichard Haseltine Posts: 112,089
    Did you install the DSON core files for Victoria 6 and Genesis 2 Male Starter Essentials, to the same location as the working Genesis Starter Essentials?
  • DimeolasDimeolas Posts: 192
    They installed automatically so if that's how its setup then yes sir.
  • FistyFisty Posts: 3,416
    edited August 2014
    Load G2F, select body if it's not, go to parameters, look under actor/people/real world. If you see Victoria 6 there try to dial her up. If she's not there or it doesn't work then try reinstalling the main DS V6 files and the Poser CFs just for good measure. You need the DS files >and< the Poser files for her to work right in Poser, same with G2M, because the Poser files have to call upon the DS files to work.
    Post edited by Fisty on
    edited August 2014
    Additionally:
    They need to be in the same place.. so it goes c:/whateverfolder/data(people, etc)/runtime(libraries, textures, etc)
    So if you have the DIM installing DS content to C:\Users\*****\Documents\DAZ 3D\Studio\My Library and Poser content to C:\Program Files\Smith Micro\Poser Pro 2014\Runtime that's why it's not working.
    thx, will check when I get a chance
    DSON is in the content folder.....I installed the G2m/f there following filepaths and of course I get the option in the menu of Poser but it just wont show up. Wsted all night on it so I think that's enough. I have trouble with the daz installer and usually have to install things by hand and never have been able to get G2 working. Poser was installed using the basic install from the cd so its installed correctly. Ill say thanks for the attempt I appreciate it but it either just doesn't work for me or else im too stupid to figure it out. Either way ive had enough of the frustrations of Daz. Take care.
