Mallen Lane - texture conversion
it8321itit8321it Posts: 0
Hello Mallen Lane
Can I use your program - Victoria 4 for Genesis 2 Female along with the surface name change converter
to remap K4 textures onto Genesis 2 male and female
The above 2 programs are already $30 so I would like to avoid having the equivalent male programs and another $30
Any known issues in this process
Regards M
  • Richard HaseltineRichard Haseltine Posts: 112,005
    Moved to DAZ Studio Discussion.
    The Kids 4 used the Victoria 4 UVs as far as I remember, so the textures should work without problems if that's right.
  • it8321itit8321it Posts: 0
    Hi
    If they do use V4 UV they can be mapped to Genesis
    But some of my output I need to put onto Genesis 2 Male
    What happens in this case?
    Regards M
    You can use the V4 UVs with the Genesis Male morph. If you are using Genesis 2 then the figure meshes are vertex and polygon identical, so the V4 UVs for G2F will work with G2M once you have the .duf preset.
