Copy & Paste Material Settings In Daz
Maybe this already exists, but I certainly have not found it yet.
I would love the ability to copy material settings on 1 item, and then to apply those settings to another separate item.
  • nabob21nabob21 Posts: 1,058
    In the surfaces tab if you right click on a material you will get the option to copy the selected material(s) and then you can paste them onto another item. It works very well but it will over-write any image maps the target material may be using. For example, I use it to copy hair materials from one hair to another, but before I paste it to the target hair I take note of what image maps the target hair may be using, such as transparency maps, bump maps etc.
    Hope this helps.
  • It's also in the Edit>Copy/Edit>Paste menu - but note that it copies settings, it won't change which shader is applied.
