Turn off "Visible in Simulation" for multiple body parts at once?
Auroratrek
This might be a dumb question, but is there a way to turn off the "Visible in Simulation" on multiple body parts at once? I can select multiple body parts at once, but changing the "Visible in Simulation" to "Off" doesn't change all the selected items, just one at a time. Am I missing something?
Are you changing the setting in the "Display" section of the Parameters? If so, I can multi-select and turn "Visible in Simulation" off or on. What I can't do is select a group containing multiple objects and turn them all off just by turning the Group to off. If I look at the individual objects within the group, they are still on. So I have to multi-select all the objects within the group in order to switch them off, which is a bit of a PITA. I think that selecting a group should select all the objects within the group but maybe there's a good reason why not that I haven't thought of.
Just re-read your question and I see you are referring to individual body parts so I tried this and was able to multi-select different body parts on the same figure and switch on or off.
On the Parameters Tab, go to the menu in the upper right and choose "Preferences", under there, choose "Consolidate Properties", as in make sure its checked. This will tell Daz Studio that when two or more nodes are selected that have the same dials, to show them as one instead of multiple dials.
Ah yes, thanks for the reminder. I do remember having to do that at some stage in the past.
Hm, I do have "Consolidate Properties" checked, but it still only changes the parameter on one body part at a time. Maybe something weird with my system. Thanks, tho!
@Auroratrek have coincidentally found your forum thread while searching for something else hehe!
Obviously a tad late to the party and you may already aware of it, but I made a product with Josh Darling to do just this - here's a link to the official thread which also has a link to the store page: https://www.daz3d.com/forums/discussion/654991/coming-soon-ultimate-simulation-visibility-commercial
