DELETE
daveso
DELETE
Post edited by daveso on
daveso
DELETE
Well, you just tick the checkbox next to Products in the "Ready to download"-tab of DIM and then you click on "Start Queue". Do have currently some 20% of my stuff installed. If I would hit that button it would take some days I guess ;-)
This does of course also work for installing and uninstalling. At least with DIM for Mac that is the case.You can check the box beside products on your ready to download tab and it will check everything in your list then just let it run., I downloaded over 100 products yesterday, all the new stuff I have purchased, in about 1 hour and only 1 of those gave me the download failed button
The failed download was the Scar 8 HD addon, and it still fails todayDELETE
Maybe if you just temporarily remove your Manifest File which says whats installed, then it will show everything for download and you can download it all then put back the Manifest file where its supposed to be?
DELETE
I you want to just set a new install to path and disable the delete upon installation. that way you should be able to archive everything.
That's how I do it:
- I download with DIM to an external 4 TB HDD which serves as my archive drive. I never delete upon installation.
- I install everything to an external 2 TB SSD for best performance.
Works fine so far. I can easily uninstall stuff whenever necessary and reinstall locally.
Only thing I need to do is consoliate the installers I've created for stuff from other sites also into DIM.
That's how I do it:
DELETE
