Modeling smoke clouds
I'm getting back into playing around with Carrara after many years and I was trying to model/ render smoke clouds like from a steam engine. Any guidance to a starting point would be helpful. Thanos.
    I like using a special map of smoke in the particle emitter. Use size over live and other emitter parameters along with clever use of the connected Shader to tweak the smoke/steam effect to look and behave how I need it to look.
    But that's just one method.
  • Steve KSteve K Posts: 3,535
    I use Carrara for almost all aspects of animation, but sometimes other tools are preferred.  For smoke, I like a 2D FX overlay program "Particle Illusion", which works with any still or animation.  One big advantage is that a 2D FX program renders way faster than 3D, in the case of "Particle Illusion" faster than real time (really).
    Here is an example I did using a smoke effect @ ~3:00 and ~4:00:
    "Particle Illusion" is available as a plugin for many video editors (I use Vegas), but has a free standalone version (which I have not used since the pre-plugin days):
    https://borisfx.com/products/particle-illusion/?collection=continuum-premium-filters&product=continuum-filter-beauty-studio
  • Sci Fi FunkSci Fi Funk Posts: 1,198
    @Steve K - looks very good in both cases. Thanks for the share - another problem I will have to face solved! Added bonus is that it works for Vegas, you and I have that in common as well.
    Cheers.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,669
    edited December 2020
    I just use an invisible fountain primitive with a tiny volumetric cloud surface replicated on it
    in Octane I don't even need to replicate the cloud as it sees the fountain particles as voxels
    Wendy - Are you using the latest Octane (via a subscription)? I noticed they were offering that, but I'm stuck with the non-subscription version, although it is up do date, I'm just getting back into the swing of things, so having to re-learn a load of stuff to make progress.
  • no I am still on Octane 4 and unlikely to ever upgrade now, if it stops working will go back to Carrara render.
    Otoy have gotten enough money from me
    My feelings too. I don't do subscriptions for software. OK so I have that option for the smoke as well. Great news. Thanks.
