use blender renderer?
Meraki
Would it be possible to render a scene from daz in blender? I have an rtx 3080 but daz takes 8h or more for each render and blender takes like a few hour
If you're wondering if you can simply open a scene in Blender and expect it to look identical to your render in Daz, then no. Cycles and Iray are completely different render engines. There are some addons and methods for a Daz -> Blender pipeline, but there's some work involved.
More importantly, a 3080 taking 8 hours to render a single scene in Daz sounds extremely bizarre.
Eight hours does seem a tad long; are you sure the 3080 is being used?
Scenes can be rendered in Blender if you use the Diffeomorphic Plugin; check the Blender thread. I do my rendering in Cycles - as I prefer it to Iray.
A tad... that's CPU render speed. Something isn't right there.
Is everything fitting in your vram? Or are you doing volumetrics? You could cut that down significantly if you do everything in layers.
