Scale Parameters Disappered
marblemarble Posts: 7,500
HI.
I have a scene loaded with V4, M4 and a room with furniture.
I decided that my V4 figure was too big and wanted to scale her down (I often do this). However, under the General Paramters, where the transforms and rotation sliders are, the is nothing for Scale. M4 Scaling is missing too. Just to check, I loaded another scene with V4 & M4 - sure enough, the Scale parameters are where I expect them to be.
Have I somehow disabled the scaling? If so, how do I restore them?
Just to be clear, I can scale the body parts (arms, legs, etc.) but not the root figures.
  • Richard HaseltineRichard Haseltine Posts: 112,003
    Right-click the Parameters pane's tab and select Show Hidden Properties. You should now certainly see the scales. Click the gear at the right of the slider and select parameter Settings, then look to see if the Hidden box is checked - if it is, uncheck it and click Accept. Now you can again right-click on the tab and turn off Show Hidden Properties.
  • marblemarble Posts: 7,500
    Excellent!
    Thanks, Richard - exactly as you described. I have no idea how I got it into that state but now I know how to get out of it again.
