Skirt deformation
Hi,
Often there is a deformation between the skirt after you apply morph to the genesis 8 female,
please see screenshot, is there a way to fix it?
I did weight node smoothing, nothing happened..
dont know how jcm would work in this case.
Please suggest and help in anyways, thanks in advance...cheers
1286 x 972 - 163K
These are projected morphs from the base figure? Unfortunately the only real fix is a custom morph, rather than relying on projection.
