Hair with small hair cap?
LauritaLaurita Posts: 288
edited December 2020 in The Commons
I love using the Neroli Hair http://www.daz3d.com/dforce-neroli-hair-for-genesis-8-and-genesis-3-females .
But the hairline is quite high on the forehead, so the hair cap is visible below it. Which makes the characters look like they shaved their forehead. I tried several haircaps from other products and did not find any improvements. Obviously I could just delete the haircap or make it invisible but the hair's density is just a bit too low so it still looks kinda off.
Does anyone know a really small haircap I could use or has another idea of how to solve this problem?
Post edited by Laurita on
  • I second this inquiry. The only reason why I skipped over buying the hair yesterday was due to exactly as Laurita described, as can be seen in the promos.
  • oh wow you actually see the haircap in the main promo blush
  • MelanieLMelanieL Posts: 7,867
    This was discussed at some length in Novica's Art Studio thread - the PA (Chevybabe25) chipped in with some possible workarounds and said that a fix was going to be made - not sure whether it has happened yet. Here's the starting point of that discussion: https://www.daz3d.com/forums/discussion/comment/6145566/#Comment_6145566
  • SevrinSevrin Posts: 6,314
    It's a pity that the haircap is such a distraction from what is IMO a really nice hair prop.  It's a trivial matter to dial out the opacity, but it's a bit strong on pale skin, especially with light-coloured hair.  I kind of like it on darker skin, though.
  • NylonGirlNylonGirl Posts: 2,365
    Why are the hair caps not invisible by default?
  • SotoSoto Posts: 1,451
    The easiest fix is to just paint black that area of the scalp opacity map in an image editor.
    Not the best approach and I doubt it will look that good, but you could also try to select the unwanted polygons with the Geometry Editor Tool and turn them invisible.
    I vote for the first option as you can control the result and it will be a permanent fix.
    Chevybabe was trying something different with this hair.
  • chevybabe25chevybabe25 Posts: 1,346
    Hi guys
    Yes I do plan on having an update for this as that other thread also states. Please check out that thread where I posted some quick solutions to get you by in the meantime :)
  • LauritaLaurita Posts: 288
    Oh great, many thanks!
