Speed Up Rendering in Daz studio
BlossomStudiosBlossomStudios Posts: 83
Hi
is they an plugin to speed up the rendering process for daz3d studios
my laptop seems to be taking long time to render
Specs
12 GB Ram
intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
Nivida GeForce GT 740M Processor
  • BlossomStudiosBlossomStudios Posts: 83
    will OCTANE Render plugin work
    got animation that is 575 frames and have done 230 frames in 1 hour 11 minutes
  • Atticus BonesAtticus Bones Posts: 364
    Yep, the GT 740M's CUDA enabled and shouldn't have any problems running Octane. Download the demo and take it for a spin.
    There are MANY different things in a scene plus advanced render settings that will affect render times
    If the sharpness of the image is not very important you can set your Shading Rate in the advanced render options to 1 instead of 0.2 which it may be set to and it will render faster. Also setting pixel samples to 4 will cause it to render faster. However this speed increase will come at the cost of image quality.
  • Constance1Constance1 Posts: 13
    For animation, if you run the Animation while Rendering, it renders much faster.
  • Mosk the ScribeMosk the Scribe Posts: 904
    Can anyone verify that? I predominantly do animations, and I do all of my work in Carrara because DAZ Studio simply doesn't render quick enough (so I'd be very interested in finding a way to speed up DAZ rendering).
    Do you simply mean hit the play button and then hit render?
  • Wedge_2659076Wedge_2659076 Posts: 15
    I noticed that no one replied to that question. Did you ever try it? I'm also trying to speed up animation rendering time in DAZ 4.7.
    Rendering 1400 frames right now. Going to take all night. Looking for solutions for the future. A new computer would help though. I'm on a 2008 Quad Core Mac Pro tower 3.2GHz with ATI Radeon HD 5770 Graphics card.
  • RuphussRuphuss Posts: 2,631
    edited April 2015
    no that's not true
    Post edited by Ruphuss on
  • StratDragonStratDragon Posts: 3,289
    also deleting things not showing in your camera but in your file helps, provided you don't need an off-screen reflection or shadow sometimes helps with speeding up.
  • FirstBastionFirstBastion Posts: 8,074
    Depending on the scene, having a pre-render background can also help, because rendering a static background every frame wastes computing time. Related to that, rendering without a background that you composite in later in an editor can also speed up rendering.
    Thanks for the options to try.
    I always check if my shadows are visible. if not I turn them off. Shadows really slow down rendering.
    my 1400 frame render is up to 15 hours now. 2 characters and a moving camera view. Only 300 frames to go.
    Raytraced shadow+displace=crawl of death
    I actually have not tried Raytraced shadows yet. Still new at all this.
    I'm wondering if it is faster to render all frames as images and not as a movie.
    Also wondering if I cancel a movie render half way thru if it will save what it has done so far.
    Not gambling on that today.
  • NoName99NoName99 Posts: 322
    edited April 2015
    Don't cancel!
    You will most likely lose it all. If you do cancel, you have a very short time frame to find your TEMP folder and copy the temp image sequence Daz has rendered.
    Rendering an animation to an image sequence is usually faster than rendering a movie as an .avi.
    As an image sequence, you can cancel your render and still have all the images you already rendered.
    Post edited by NoName99 on
    ^^ +100
    ^^ +100
    Agreed. Sadly in this case I am animating a moving camera scene so my background is different in every shot, slightly.
    Thanks for info about the temp file.
    web said:
    ^^ +100
    You can still pull it off, depending on how much your camera is moving.
    The trick is to apply the background image as a material to a primitive plane. That way the primitive plane moves in 3d space along with the camera and characters in your scene.
    If it's an excessive move, like a 180-360 spin like Michael bay & Tarantino like to do, it won't work. But if is just a dolly in/out or pan, I can still save you time.
    Did anyone bother to run the math on the original post?
    Around 30 SECONDS/frame is slow? 230 and frames in 71 minutes...that's 230 rendered images in 71 minutes.
    This isn't a real-time render engine, you are NOT going to get much faster than that!
    Anything at 1 minute or less per frame is NOT all that slow.
    edited April 2015
    Lol, that is insanely fast. I'm happy If I can get under 5 minutes per frame.
    I just saw the question and didn't add that up at all.
    This begs the question.....
    Web, how are you pulling this off??
    I'm like yeah...the few animations I've done, I was very happy with less than 3 mins per frame....and that was on my old computer. I haven't tried rendering on this one (it's a quad core as opposed to dual, so I imagine it will be faster).
    But one way to speed up a render...still or animation is to use an external renderer (3DL standalone will usually be faster than the included one, but it does require some prep work for animation use and/or Mac use, which may negate some or all of the speed increase).
    dinopt said:
    web said:
    ^^ +100
    This one is a 360 spin. But good to know info if I'm doing a simple zoom or even pan.
    Did we read the first post? Yes
    What was the 2nd question?
