Not Able to Save Modifed Assets.
BurstAngel
I've trying to move some morphs in GF2 but it won't save the change. I double check to make sure I have the latest Studio. I'm trying move the morphs of Lucille and OOT Milena to my prefer spot and organize the morphs to my preference.
What is it that you are trying to save? Are you trying to move the morphs to a different group in the Parameters pane for example.
Are you trying to change the folder that your morphs are in?
A fuller description of what you want to do would help.
I'm trying to move the morphs in the parameters.
A recently released way to do it fairly easily is this : http://www.daz3d.com/morph-organizer-for-daz-studio
How are you trying to do this at the moment, if we know, then maybe someone can point you in the right direction? Can you go through what way you are trying to move these, and save them?
Oh, I have that! It is fantastic, I was able to move my morphs around so it would make sense. I tries both ways, with the morph organized and within DAZ. It just refuses to save it my preferred parameter location.
I just tried this, and it moves a morph to a different group. I used Edit Mode, then Set > Property Group to move it.
The move worked OK, but when I exited DS, and loaded it again, the morph was back in the original group, so it doesn't work for me either (if that was the way you did it).
I would have thought that Morph Organiser would have worked, because it changes the DSF file I believe, why that is not working baffles me. I can only ask you to hang on in case someone else who knows how to work this reads the thread. In the meantime, I will try to find out more for you.
Yeah, Usually the morph organizer does the trick, except for a few morphs where it fails. Can't figure out why these morphs would be any different than the rest. But Thank You for the helping hand. I'll keep my eye out.
