Can't install update through DIM :(
sandrabauser
Hello! Every time I try to install the new DS 4.6 update, DIM tells me that it can't find where the original install path is, even though I have all the application paths set up correctly :/ I cannot figure out why it isn't seeing it! Anyone have any suggestions?
Thank you!
Sandra
Do you have a version of DS 4.6 already installed?
Did you set the path in the DIM in the Applications tab as shown below? Are you sure that you are downloading the correct bit depth for your system (32 bit or 64 bit)?
Yep...checked all my installation paths and such...ended up uninstalling the old version and then the reinstall and update went fine...I guess it just didn't like the old install path I had...I didn't have it in the default path before, but this time I let it reinstall in the default location. DIM is now recognizing the pathway. Thank you for your help! Appreciate it :D
Those Gremlins get in everywhere :) Glad you got it to work.
Yes they do! Thanks again :cheese:
