M4 Injection morphs and Daz Studio 4.6 - help please.
CrystalwizardCrystalwizard Posts: 102
I can't figure out what I'm doing wrong. Studio loads fine. M4 loads fine. I pick one of the injection morphs for full body - say heavy - select M4 and double left click the morph. A small box pops up and a yellow highlight runs across it - indicating that it's loading the morph.
But when I go to the posing tab OR the parameters tab, I can not find anywhere to set the morph that's loaded. I have looked through all the sliders for every single part of M4's body starting with just michael 4 and going through the entire tree.
So, can someone PLEASE tell me where to find the sliders for the morphs so I can actually set them and have them affect the figure?
  • Cris PalominoCris Palomino Posts: 13,051
    IIRC, the injection morphs required that you have those installed in the same place as your M4....you used the .bat file on M4 when you installed it?
    I just tried this, and it works for me I'm afraid :)
    The first time I clicked on the icon for 'Heavy.PZ2' it did not seem to do anything. I checked again, made sure that M4 was selected in the Scene pane, double clicked, and I got the yellow bar. I had the Parameters pane open at the time, and I could see that something had been added.
    I then had a new group in the Parameters pane (I don't use the shaping pane) called 'Morphs | Shapes' and inside that is Morphs++ and Full Body. The slider name is just 'Heavy'
    I loaded M4 using the Powerloader, but I had Morphs++ and Base unchecked, so that it only loaded M4
  • CrystalwizardCrystalwizard Posts: 102
    What bat file? I downloaded the .zip file for all of the m4 stuff - base and morphs, and unzipped them into the same folder.
    I can get the morphs to show up just fine in poser. it's in Studio that nothing happens. And I'm loading them out of the same directory in both programs.
    how do you use the powerloader?
  • Richard HaseltineRichard Haseltine Posts: 112,003
    If the morphs are working in Poser you don't need a separate installation for DAZ Studio - just point DS to the Poser external library folder (the one that holds the Runtime folder) as a Poser Format directory (add a directory by right-clicking on Poser Formats in the Content Library pane).
    You should have 'Michael 4 Base Powerloader' in your DIM downloads. There is also one for Morphs++ called 'Michael 4 Morphs++ Powerloader' Install them, and when you double click on the CR2 in DAZ Studio, Powerloader will pop up and you can select what morphs you want to load along with the Base figure.
