How to get V4 into D|S 4.6?
StarkdogStarkdog Posts: 176
Ok, so I have re-installed a bunch of content, including V4 via DIM. I see the V4 icon, but when I select it, i get an error saying it cannot find the V4 support folder. What do I need to do in order to get V4 to work in D|S?
Thanks,- Starkdog
576 x 210 - 29K
  • FistyFisty Posts: 3,416
    There is a .bat file you need to run to get her to work. i can't remember exactly where it is though.. somewhere in runtime. Not at my main PC right now to look, hopefully someone will pop in soon that knows the location.
  • SassyWenchSassyWench Posts: 602
    The .bat file for me is in: C:\Users\xxxxxx\Documents\Daz 3D\Studio\My Library\Runtime\libraries\!DAZ
    Hope that helps :)
  • nightwolf1982nightwolf1982 Posts: 1,343
    DIM Should have automatically run the batch (.bat) file to set up the EXP for V4. You should try uninstalling and re-installing V4 first. Make sure that you install both files - there should be one called Victoria 4.2 Base and another called Victoria 4.2 Base StudioCF.
    If, after re-installing, the figure still won't load, you'll need to go into the runtime where you install her and run the .bat file - Runtime/Libraries/!DAZ/DzCreateExPFiles-V4.bat
  • edited December 1969
    HI, I have a similar issue. I used DIM to install Victoria 4.2 both files and I can only see the UV files in my DAZ3d, have tried several times uninstalling/reinstalling. Also, see no .bat files in any of my Runtime directories or subdirectories.
    Ideas?
    thanks,
    Kit
  • HavosHavos Posts: 5,711
    If running with Windows Vista, 7 or 8, you could try and run DIM as Administrator before installing V4, maybe the bat and/or exe's are not running due to permission issues.
  • fixmypcmikefixmypcmike Posts: 19,742
    Ideas?
    thanks,
    Kit
    Are you sure you installed "Victoria 4.2 Base" rather than "Victoria 4 Shape for Genesis" or "Victoria 4 for Genesis 2 Female"?
