problems witrh m5 and v5
Hey all, thanks in advance for any and all advice. I just recently got m5 and v5. When I try to load them, they come out all wrong. Michael comes out with breasts and Victoria comes out emaciated. I can fix this manually but I'd like to have them load with the proper stats before I mess with their shape.
You must have overwritten the M5 and V5 base DUF files at some stage.
Are you loading M5/V5 from the People > Genesis > Characters folder, or are you loading Gebnesis first?
Please do this...Load M5 as normal, then look in the Parameters pane under Currently Used, with M5 selected. The figure must be using some other morphs, what are they?
To fix this, you would need to set these morphs to zero, and when you get the correct shape back again, save that over your current copy of M5. Then do the same with V5, but let me know what morphs are being used first please?
I'll try that, but I don't know how I could have saved anything over the base DUF's because as soon as I downloaded M5 and V5 from Daz I tried to load them and that was just how they loaded. None of my other genesis models do that.
