Issues with Anatomical Elements from Third Parties
Hello Everyone,
I've been trying to figure out what is going on with the new Daz and Geografting. The same process I do in 4.10 Daz works fine, but the same thing in anything past 4.10 seems to offset the Female Genitalia to only want to be placed based only on the location of where it would go on a Base Gen 8 Model. So for this example, a Gen 8 Model Suki will just have her Genitalia a bit shifted forward where the body of the Gen 8 Base model would be. So pretty much the Genitalia only wants to work with a Base Gen 8 Model and none of the more unique Gen 8 Models you can get. Granted this is in any Daz Past 4.10 version. In the 4.10 Version it just works with any Gen 8 Model. I can try and post pics but not sure of the rules and would not want to post anything NSFW if it is not allowed so I will wait. I was just wondering if anyone else has dealt with this or what other people do?
P.S. - The Female Genitalia GeoGraft works on the Base Gen 8 Female Model in current Daz but I want it to work on other versions of Gen 8 which it does not unless I use 4.10 Daz
Any Thought or insight would be great
Post edited by Chohole on
  • Is this only the third-party sets or is it affecting the Daz Anatomical Elements too? They are fitted to the figure? What happens if you load the base figure, add the Anatomical Elements, then apply shaping and mateials presets for the character you want to use (rather than using the character preset to load the figure in)?
    If you do need to show images later on, try to crop to show only the edges and put the Viewport in Smooth Shaded mode (or remove all textures from the figures).
  • alan bard newcomeralan bard newcomer Posts: 2,424
    edited November 2020
    Issues with anatomical elements has been the delight and bane of the human race for millions of years... Particularly if there's a third party involved?
    Post edited by alan bard newcomer on
  • onixonix Posts: 282
    If geograft gest shifted I suspect that It gets scaled wrong.  For me that stuff sometimes happened when scale slider is locked
    another similar situation happens when smoothing modifier is enabled on geograft
