16:9 Camera
geoff6geoff6 Posts: 250
Hi guys,
Does anyone know how to get the camera into a 16:9 aspect ratio? Or at least show what a 16: aspect preview would be without having to jump to the render window to check framing?
If the option is already there, I can't seem to find it.
Thanks in advance,
G
    None that I know of? There are about 20 different ratios that can be used, so it wouldn't be practical I suppose.
    You can put the Render Settings icon on the Toolbar so that it is easier to get at, but that is the only way I know of to make it any easier. You should see the Aspect Frame, and that will tell you what mode the Render Settings are in - is that what you mean?
    Go to the drop-down menu in the viewport, and make sure that Show Aspect Frame' is ticked.
  • FirstBastionFirstBastion Posts: 8,074
    edited August 2014
    As mentioned above, theres a drop down in top right hand corner of the viewport to checkmark: show Aspect frame
    1137 x 541 - 133K
    1240 x 474 - 139K
  • geoff6geoff6 Posts: 250
    Yep, got it!
    Thanks very much for your help
    Happy rendering,
    G
