4.14 Default Interface?
Just a quick question...I've noticed that whenever I open up 4.14, it seems to revert back to the default interface. I don't customize all that much, but I lose a couple of my script menus (the ones by V3Digitimes) so I have to re-run those scripts to get the menus back, and the couple tabs I normally keep added (and a couple removed) are all back to default. Is there a way to make 4.14 remember how I have everything laid out?
  • FSMCDesignsFSMCDesigns Posts: 12,858
    I don't know about 4.14, but in previous versions just get it set how you want and then save the layout (window - workspace - save layout as)
  • Yes, save your layout - but unless you have used command line switches to tell DS to load clean it should recall your previouss ettings. Are you allowing DS to close or are you ending the task manually through Task Manager?
    I just close it via the "X" on the window (unless it freezes, of course). Previous to 4.14 I never needed to tell it to save my layout. I'll give that a shot. I don't customize a lot, but it's still annoying to have to move stuff around every time.
    This morning it decided to behave itself, so I have no idea what it was doing before, lol.
  • fastbike1fastbike1 Posts: 4,085
    Still and all, it's not a big effort to save your workspace when you routinely use a 'space modifed from the Studio standard choices.
