What does these warnings mean?
albert.karinalbert.karin Posts: 0
In my log i find a number these warnings at startup of a blank studio:
For example:
WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: GenesisFemale:/data/DAZ 3D/Genesis 2/Female/Morphs/FWArt/Neomi/Neomi.dsf#Neomi_Body?value in file : /data/DAZ 3D/Genesis 2/Female/Morphs/FWArt/Neomi/Neomi.dsf
WARNING: fileinput\dzassetdaz.cpp(5613): Could not find property for animation: #PBMStomachLowerDepth:?value
What is the solution?
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,990
    I'm not certain, usually you see that kind of warning when you have a shape that includes correction morphs so that it works with another morph - for example making sure the eyes close correctly when the close morph is used with the Girl or Aiko morphs - and you don't have the morph that it correcting; that's harmless, it just means the correction won't do anything which is what you want. However the text of the warning doesn't match what I'd expect in those circumstances.
  • albert.karinalbert.karin Posts: 0
    There are a LOT of these warnings in the log.
    I think it is better to fix this problen (if there is a fix)
    Is it a problem/ Is anything not working? As i said, most such warnings are not indications of an actual problem though I'm not sure about the specific one quoted.
