Can't navigate the HDRI after the update
nenufar099
I don't know if this have been brought up before, but after the update I can´t navigate the HDRI background.
I started using DAZ around october and I'm still learning my way around it. Before the update I selected a HDRI background in the render settings, and in the Nvidia Iray preview I could move around it until I found a spot I like. Now the background is just a static picture.
I already change the background in the environment settings, in the render settings, and in the new envionment options in the scene. I don't know what else I have to do.
The pictures below are of the Light probes tool in the texture Shaded preview and the Nvidia Iray preview.
1920 x 1039 - 360K
1920 x 1039 - 384K
It seems to work for me, if only with the default map since all my hfrs are buried in sub-folders in /data/cloud/. What do you mean when you chaneg the background - if you are using Window>Panes(Tabs)>Environment then that fills the background with the whole of the selected image, which looks the same regardless of angle of view.
Thank you for answering, it's working now.
I was slow to realise that now for the environment options in the render settings to work you have to create first and environment node in the scene.
I got confused and so i used the environment tap and place a picture there. And when I finally created the environment node and the tonemapper node, it didn´t work because the still picture was interfering.
Sorry I'm very new with 3d programs. Thank you again.
