Bunny's nightmare Outfit problem
So I bought the Bunny Nightmare Outfit that just came out and there is an issue with it.
Whenever I use a pose for my figure the bodysuit of the outfit does not follow the figure, the accessories does but not the suit.
Why is this happening ???
  • 3Diva3Diva Posts: 12,058
    Did you select the bodysuit and right click and "fit to" Genesis 8 Female?
    Yes I did and the suit stays up in the air.
  • martin36martin36 Posts: 187
    edited November 2020
    I have same problem. This product is [not cooperating]!
  • Will the issue get fixed or I should just ask for a refund ?
  • LeanaLeana Posts: 13,661
    Well first someone needs to report it to Daz via a support ticket, or they won't know it requires a fix. It will probably be fixed, but there's no guarantee it will be fixed quickly.
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,910
    [botheration] was interested in this maybe wait get later then
  • RuvikRuvik Posts: 0
    I have same problem. This product is [not helpful]!
    Me too!help!!!!
  • Please put the Viewport into Smooth Shaded view rather than applying a black bar across the breasts in your illustration of the issue.
    Since this is clearly a widespread, most likely universal, issue please open a support ticket to report it.
  • This is a great suit, but I too am having problems with it following body poses. Hopefully it'll get patched soon, because its pretty busted right now.
    Also, I can't find the shape morphs for the Bunny Breast and Bunny Torso that were suppose to be part of the package. Not sure where those are hiding.
  • SevrinSevrin Posts: 6,314
    Those apply to the character, not the suit, so you'll need to select the character and check shaping parameters for something with "bunny" in the name or try the Shaping folder.  The product has no readme, so you'll have to poke around.
  • I purchased the outfil Nov. 22. 2020 and I experience the same problems.
  • evacynevacyn Posts: 993
    Not sure who else submitted a ticket, but I did as well. I really like Blue Rabbit's work, so I'm hoping they'll be able to fix it.
  • GuyBcapsGuyBcaps Posts: 37
    Found them. Bunny Best is in Breast Shape (naturally), but Bunny Torso is in Waist morphs of all places, because it's a waist morph and should probably be called Bunny Waist.
    Post edited by GuyBcaps on
  • Not only this, but some shaping morphs also don't transfer over to the suit, height and chest width and depth morphs on figure don't effect the suit, this has to be the buggiest piece of clothing I've ever bought.
  • Here's hoping it gets fixed soon. I bought the Bounce Outfit awhile back, it had the same bunny girl outfit concept and all, but I was interested in picking this one up because of the poses and morphs included, but if the outfit isn't even rigged to follow the body, what's the point. :/
    in the old days  like ver 4.7, increasing the smoothing iterations could solve some fitting issues.
  • I've contacted the vendor, Blue Rabbit, via Deviantart. They say the outfit works fine for them, but has also said they have contacted DAZ for a fix and offered a temporary solution for those who can't wait. (Note: The "Transfer Utility", the circle-arrow thing, is under Edit -> Object or Figure).
    1]) load the genesis 8 female model, without any morph and with the base pose.
    2) you load the bodysuit on your model, as if you were going to use it, selectin your model before load de cloath.
    3) On the right hand side there should be the transfer icon, which is a circle with an up arrow, if you don't have it, look for it in windows - panels.
    4) Execute it.
    5) in source you choose genesis 8 female, and in target, you select the bodysuit and accept.
    After it is bound, it should work, and you can overload the base Genesis 8 Female with a character of your choosing. However, this is a temporary fix; you will have to do this with every character you want to load with the outfit, unless you can "save" the outfit:
    If you want to save it so you don't have to do it over and over again, it's a bit more complicated because you have to know in which folder the file is stored, but if you still want to save it, let me know and I'll give you directions.
    One last, unrelated thing; In case you haven't figured it out already, the stockings isn't part of the bodysuit piece, nor is it in the base Wardrobe tab. Instead, look under Materials -> Iray -> Wardrobe while the character is selected.
  • Hi People! Im really sorry about this. I tried that the fix was the sooner but it took a little longer, but now it is fixed, you can update de file directly by daz or redownload the file, dependig how metod you use to download it he first time. thank you and my apologies again.
    Blue Rabbit
  • ArtiniArtini Posts: 11,034
    I have redownloaded the file, but have not used it yet.
    It was really a nightmare outfit, that fits only lower part of body, leaving the breasts visible.
    Hope it is fixed with the update.
  • ThyranqThyranq Posts: 589
    Works fine for me now!
  • Guys! I have made some extra poses to use with the Bunny outfit or another outfit you want, you can download it here.smiley
    https://www.deviantart.com/bluerabbit-daz3d/art/Bunny-poses-for-Bunny-s-nightmare-Outfit-862748161?ga_submit_new=10%3A1606782415
  • Thank you for those.
    Thank you for fixing it so quickly ... and the poses are awesome too!
    Awesome! Thanks for the free poses!
    Thank you! Works great now!
