Measure Metrics keeps changing measurements.
I've had this problem ever since I got the attachment, Measure Metrics, ever since their update last year. Everytime I try to change the measurements of a female figure the program will change the height and other measurements. For instance, I increase the bust size, the waist and hips changes, as well it makes the figure taller. Any idea out there on how to correct this problem?
  • fixmypcmikefixmypcmike Posts: 19,741
    Configure which settings you want it to be permitted to change.
  • and which property are you using to make the changes - you want, as far as possible, one that affects only the dimension of interest.
  • Sorry, but I have no idea what you two are saying. But I was finally able to get it to work correctly after some trial and errors.
