Errors in log file on startup of DAZ Studio (v 4.15.0.8)
vonHobovonHobo Posts: 1,715
Does anyone know why I would receive these errors for 3DConnexion Plug-in and 3D mouse support library in the log file when starting DAZ Studio?
To be fair, I may have been receiving these two errors for a while, even before the latest version. I'm just having some issues saving scenes (Studio stops responding) so I took a look at the log file and noticed these errors (in bold):
2020-11-20 00:04:07.957 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : iray photoreal CPU fallback is enabled.
2020-11-20 00:04:07.957 Iray [INFO] - IRT:RENDER ::   1.0   IRT    rend info : Resource assignment for host 0 has changed.
2020-11-20 00:04:07.961 NVIDIA Iray GPUs:
2020-11-20 00:04:07.961 GPU: 1 - GeForce GTX 1070
2020-11-20 00:04:07.961 Memory Size: 7.9 GB
2020-11-20 00:04:07.961 Clock Rate: 1683000 kHz
2020-11-20 00:04:07.961 Multi Processor Count: 15
2020-11-20 00:04:07.961 CUDA Device ID: 0
2020-11-20 00:04:07.961 CUDA Compute Capability: 6.1
2020-11-20 00:04:07.961 PCI Bus ID: 1
2020-11-20 00:04:07.961 PCI Device ID: 0
2020-11-20 00:04:07.961 TCC Mode: disabled
2020-11-20 00:04:07.961 Display: attached
2020-11-20 00:04:07.961 NVIDIA Iray Scheduling Configuration:
2020-11-20 00:04:07.965 CPU Load Limit: 12
2020-11-20 00:04:07.965 CPU Thread Affinity: disabled
2020-11-20 00:04:07.965 GPU Load Limit: 1
2020-11-20 00:04:08.147 Total class factories: 2081
2020-11-20 00:04:08.148 Creating Script Engine...
2020-11-20 00:04:08.161 WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
2020-11-20 00:04:08.161 3D mouse support library could not be loaded.
2020-11-20 00:04:08.162 Creating Main Window...
2020-11-20 00:04:08.162 Creating Viewport Manager...
2020-11-20 00:04:08.214 Successfully created OpenGL viewport for Viewport1.
2020-11-20 00:04:08.315 Successfully created OpenGL viewport for Viewport2.
2020-11-20 00:04:08.381 Successfully created OpenGL viewport for Viewport3.
2020-11-20 00:04:08.447 Successfully created OpenGL viewport for Viewport4.
2020-11-20 00:04:08.516 Creating Action Manager...
2020-11-20 00:04:08.525 Creating Pane Manager...
2020-11-20 00:04:08.777 Successfully created OpenGL viewport for AuxViewportView.
2020-11-20 00:04:09.529 Executing startup script...
2020-11-20 00:04:09.592 Started in: C:/Program Files/DAZ 3D/DAZStudio4
2020-11-20 00:04:09.592 DAZ Studio Started
2020-11-20 00:04:09.593 Creating Pixel Buffer
2020-11-20 00:04:09.631 Pixel buffer - Width: 1024 Height: 1024
2020-11-20 00:04:09.632 Compiling OpenGL Shader...
2020-11-20 00:04:09.634 Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Shader Program successfully linked.
2020-11-20 00:04:14.593 Compiling OpenGL Shader...
2020-11-20 00:04:14.596 Vertex Shader:
Vertex Shader compiled successfully.
Fragment Shader:
Linking Shader:
Post edited by vonHobo on
    That means you don't have hardware, which those are for
    The error just informs you that DS could not enable functions related to the espresso maker
  • vonHobovonHobo Posts: 1,715
    Thank you. I have to look into that. I love espresso!
    @von Hobo
    If you don't have the hardware, you can disable those plugins. In fact if you have plugins enabled for functions/software/hardware you don't use, you will likely see performance benefits if you disable the associated plugins.
    "Help>About Installed Plugins"
    edited November 2020
    fastbike1 said:
    @von Hobo
    Thank you! I disabled the 3DConnexion Plug-in and DAZ Studio seems to load quicker now.
    I wonder what the deal is with the 3D mouse support library. Because I could not find a plug-in for that.
