File > Save Last Draw bitmap / can a script access that?
Is it possible to get the draw buffer that is written by Menu > File > Save Last Draw,
or at least to trigger that save function from a script?
My script currently does [...].get3DViewport().captureImage(),
but this is not the same thing (tools overlays, render aspect ratio, ...)
Thanks for any insights
  • There are a couple of samples that may help you if you want the action:
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/actions/action_find_classname/start
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/actions/action_trigger/start
    If you want the raw data for further processing I don't know if that is possible, other than by saving a file and then loading it back in.
  • cajhincajhin Posts: 154
    Thanks Richard, once more I'm impressed by the breadth and depth of your knowledge (or your search skills - do you have a private search engine??)
    Close, but no cigar. Triggering the action "DzSaveLastDrawAction" does not accept any parameters, so "save the draw pane to file, then load that file" always opens
    "Save Image" dialog, where the user must navigate to the correct folder and save the temp file with the correct filename. Nope...
    Well, it was worth a try.
  • Try http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/rendering/render_drawstyle/start
    (these, by the way, come from Rob not me - though I do now recall some of the relevant samples without prompting.)
  • I know it's been a while so I don't know if you're still looking for your answer, but I found myself trying to to the same thing yesterday and your post nudged me in the right direction.  So, if it helps:
    var outPath = "IMAGE PATH";var vp = MainWindow.getViewportMgr()		.getActiveViewport()		.get3DViewport();// Turn off aspect frame so it's not shown in the output imagevp.aspectOn = false;// Find the position and size of the aspect frame over the viewportvar iDim = [vp.getAspectFrameRect().x,	vp.getAspectFrameRect().y,	vp.getAspectFrameRect().width,	vp.getAspectFrameRect().height];// Capture the viewport and then output a copy of just the portion inside the aspect framevar img = vp.captureImage().copy(iDim[0],iDim[1],iDim[2],iDim[3]);img.save(outPath);vp.aspectOn = true;
    I also encountered a couple of other issues, such as the menu icon overlapping the draw even with most things on auto-hide.  To get around this, I grabbed the pane manager object, undocked the viewport pane and resized it taller than the aspect frame enough that the menu icon did not overlap.  Also good for if you wanted a larger version of the draw; I use for Iray preview so pop out, resize, wait for draw and then save, and return everything to normal.
    I did find grouped nodes had those annoying crosshairs, of course, so I also added a couple of steps to clear any selection and unparent anything under a group node before the draw and reparent them back again afterwards and restore the selection.  Might find other steps are needed if you have any other things with indicators that hang around even when not selected.
    Bit more of a pain than just triggering the Save Last Draw action, but it got me where I needed to be.
    I'm curious if anything related to this has changed since the question was first asked?
    The reason to use the "Save Last Draw..." action is that the draw has already happened, so saving it is instantaneous. Also, it might just be me, but I haven't figured out how to get Iray drawstyle to render. When I have the draw style set to Iray and render engine set to Viewport I get a worthless render. If I'm missing something I'd love to hear.
    Do we have access through script (other than by calling the action) to save the last draw? Either by direct access to the API calls or the newer triggerWithSettings() method?
  • This script does something similar, I think, to what you're asking. I use it to capture iray previews (i.e. last draws) from all the visible cameras in a scene when I need to do rapid "storyboarding".
    It does ask the user for a target directory to write the last draws to, and it pops up a progress dialog to let the user know how far it's progressed.
    It should be trivial to remove those features and just hardcode the target directory or pass in as a scriptArg.
  • sidcarton1587sidcarton1587 Posts: 116
    edited November 2025
    Well scratch that, I noticed that you had mentioned the overlays getting into the image. That's been good enough for my purposes in terms of storyboarding but I can see where it would get in way.
    Let's see if the script can be refined to hide those things automatically.
    Off the top of my head, you can hide the camera cube and enable auto hiding the view options and view controls (manually, not through a script). The script could also be updated to make all the visible cameras invisible right before capturing the last draws, then turning them back to visible to restore state. That does seem to do the trick. If you set the render dimension preset to "Active Viewport", it seems to render a series of last draws with only the tiny "hamburger" menu icon in the upper visible. Though as others have pointed out, if there are guides or lights, won't get rid of those. Sigh.
    Post edited by sidcarton1587 on
  • It has been a bit since I looked at this but I think I got it working relatively well. I did find that you can hide the floor, pose tool, camera cube and all that through the viewport. You also have to hide group nodes or any other node that has no geometry like was mentioned by deranged_seamonkey
