Help - Content in the Content Library and not in the Smart Content.
I downloaded the install manager and installed Daz studio from their and all my content is in the content library but not in the smart content - What feature am I not setting correctly - I have the Hollywood Blvd workspace set - The props and sets are in the smart content pane but everything else isn't -
No genesis content or anything - Just the Victoria 6. I download daz all the time through the install manager and it's always worked before.
Sorry Again = I re imported the Metadata and all is well -
https://helpdaz.zendesk.com/entries/22523891-Trouble-shooting-the-Smart-Content-Pane
RE-IMPORT THE METADATA
Sometimes you can simply re-import the metadata for the content database and you will see your content items again. To manage this data, click on the 'Content DB Maintenance…' option. You may need to use this option a few times.
This is how to access the 'Content DB Maintenance…' option in DAZ Studio 4.5. Go to the Content Library Pane (WINDOW –> Panes –> Content Library). In the Pane, find the 'Active Pane Options' button which is on the top. It will be on either the top left or top right, depending upon when the pane is docked. The button icon has four horizontal lines and a triangle.
Click on the 'Active Pane Options' button in the Content Library Pane. A menu will appear. Find 'Content DB Maintenance…' in the menu and click on it.
You will now see several options in the Content Database Maintenance Window. First choose 'Reset Database' and then click 'Accept.' It may not appear to do anything. Return to the Cotnent DB Maintenance Window and this time check 'Re-Import Metadata…' Check the box for 'Show Content as New' in the lower left and click 'Accept.' You should see another window appear with all the metadata for the various content items listed in it. Press 'Accept' below. Now you should see a progress bar asDAZ Studio re-imports and thus rebuilds the database. It may take several moments to do this. If you see the progress bar flash very quickly or if it appears that nothing has happened, it is likely the database is broken and will need to be rebuilt as explained below.
After the data files have been reimported, check the Smart Content Pane. If you still do not see any content, then proceed to the next step below.
