problems with Measure Metrics
Hi! Sorry for me English)
I want to use the script, but I can't figure it out. I go strictly according to the instructions, but I can't select the second line For "02 Bust Circumference, the node is set to “Genesis 2 Female”, and the property is set to “Actor > Upper Body > Chest > Real World > Measure Metrics > (Bust Circumference)". They just don't exist. Help)
  • How did you install the Figure Metrics content, assuming you did?
  • If I may jump in this thread, I haven't used Figure Metrics (I assume this is the same as Measure Metrics) in awhile, but when I ran the utility today I don't have the info dialog showing anywhere. Probably a stupid question but how can I get the Figure Metrics dialog to show?
  • Richard HaseltineRichard Haseltine Posts: 111,363
    edited December 2020
    Measure Metrics is the plug in which allows the creation of measures. Figure metrics is a set of preloads to place figures in a speciifc pose and apply a set of Measure Metrics measurement nodes, which a script then uses to populate a dialogue box showing the vital statistics and, with suitable properties selected, to adjust the figure in an attempt to match desired values. Theya re separate installers; Measure Metrics must be installed through DIM/DazCentral/manually - do you have the whole thing installed and have you entered the plug in's serial number? The Figure Metrics script is in Script>Utilities
    THANKS so much for the explanation. I assumed Measure Metrics and Figure Metrics were the same product ... DUH! ... Really appreciate your help.
