Quick Question about dForce clothing?
DDCreateDDCreate Posts: 1,421
When an item in the store says it's dForce clothing does that mean it ALREADY has the dForce modifier and weight node added to it or does that just mean it's built to drape using dForce but you still have to add those?
  • It will already be set up, with the modifier and any needed weight maps (but not necessarily a weight node to access them).
  • DDCreateDDCreate Posts: 1,421
    Ahhh. So be safe and add the node. Got it. I ask because I have some that were advertised as dForce and when I simulate, they don't really do anything. I've even returned a few over it. Thanks Richard.
  • The only reason to add the weight node ius if you want to edit the weight maps - all it does is provide a way to access them with the Node Weight Map Brush tool, deelting it doesn't remove any maps applied or affect the function of the item in dForce.
