Help with install supersuit creature pack
I am trying to install the genesis creature pack under my user id in win 7 64 bit. It tell me i did not install the super suit pack first. The super suit pack and meta data both show in my uninstall folder under my user id. I am a new user this is my first week and the file structure for this program blows my mind. Some are stored in public and some under user id. Files seem to be all over the place in this program, Under Programs and programs x86. The installer has the default install path and in the program the content manager has both public and my user id in the settings for content. but if i load the creature pack under public the only place it will let me load if does not show in contents in program. Is this a bug for program . Please help if you can.
Can you post a screenshot of your Content Directory Manger. Edit > Preferences > Content Library > Content Directory Manager, with the expanded listing for both DAZ Studio Formats and Poser Formats?
When installing content using DIM (DAZ Install Manager) you must select the library that you want the content installed to. If you have more than one library, then make sure that items that rely on one another being installed, are installed to the same library, otherwise DAZ Studio will not be able to find them.
If you use DIM to install, then you will have (by default) a library called 'My DAZ 3D Library'. If you have other libraries that you created yourself, then you must list them in DIM so that you can install to them instead DIM only installs stuff to the library that you have selected.
