Problem transfering H3 with GenX2
Daniel BarnettDaniel Barnett Posts: 389
I'm getting the following error -
GenX - Transferring morphs.
Loading target geometry ...
Loading figure ...
P:/My DAZ 3D Library/data/DAZ 3D/Genesis/Base/Genesis.dsf
Applying shape morphs to target ...
Error loading target morph: CloneHiro3
Thank you!
dbb
  • fixmypcmikefixmypcmike Posts: 19,706
    Do you have the H3 shape for Genesis installed?
  • LyonessLyoness Posts: 1,639
    also check to make sure that everything is loaded into the main runtime... genx will not load things up from a supplemental runtime.
  • Daniel BarnettDaniel Barnett Posts: 389
    Can you be more specific - which H3 shape are you referring to?
    What runtime would you consider the main runtime?
    I have multiple runtimes... working, scenery, male, animals, etc. So, I personally have to move my data & apply/rem folders (from the working runtime) to the primary runtime (which is the one that daz studio loads the genx program/script from.
    If you only have 1 runtime then all of this doesn't matter ;)
    OK I understand which runtime but the shape thing - are they referring to this product?
    http://www.daz3d.com/genx-addon-gen3-bundle
    Thanks,
    dbb
    ok.
    here is the product description:
    This add-on extends Genesis Generation X2 (GenX2) to the world of the generation 3 figures. Now, it's possible to transfer morphs for Victoria 3, Michael 3, Stephanie 3 Petite, David 3, The Freak 3, Aiko 3, and Hiro 3 to Genesis and Genesis 2.
    what that means is that genx2 doesn't automatically come with the body shapes to convert Generation 3 products. You need this addon product to be able to accomplish the conversion.
    Lyoness said:
    ok.
    OK that is what I'm trying to do but I get the message
    Loading figure ...
    and
    Error loading target morph: Hiro3
    when I use the cr files from the main runtime folder so I'm not sure what shape I should be using!
    dbb
    Loading figure ...
    and
    dbb
    ok. I think I finally see the problem.
    #1 Load base hiro into genx (not genesis)
    #2 Apply the hiro morph (charles or whatever it's name is) that you are converting
    #3 adjust the settings as needed and convert.
    #4 save save save
    you really need to review the instructions for this addon.
    They are located here: http://d3d.sesseler.de/index.php?software=dazscript&product=genx
    I've read them over and over and over... and I'm STILL learning. (and I use the product fairly regularly)
    Loading figure ...
    and
    dbb
    #4 save save save
    Thank you! I'll check that out. I believe it's the shapes that I'm missing. I thought I had them all but I don't so it's off to check my account balances!!
    dbb
    Does anyone know if Fantasy Shapes for Genesis work with GenX2 to transfer them to Genesis 2 male/female?
    Thanksdbb
    Thanksdbb
    They ought to. You just need Gen2F and Gen2M addon.
    Thanksdbb
    I'm not sure what add-on you mean? It seems like there are a lot of add-ons!?
    The important thing to notice is whether you have genx or genx2. The addons are not interchangeable (from what I can tell).
    if you are converting anything to genx 2, you will require the gen2 female/male addon.
    If you are converting HIRO, go back and make sure which version you have to double check the addon that you installed is correct. The next step in your journey is making sure that all your software is working right... which version of genx do you have? did you get the right addon for it? If you are not sure, go to your account and look up your purchases!! We can then narrow things down and get you working!!
    I found that I didn't have the Gen3 shapes so I picked them up yesterday.
    From what I can gather I need to have all of the following items to make all versions to Genesis 1 and both of the Genesis 2 male/female shape files!
    Gen 3 Iconic Shapes for Genesis
    V3 and M3 Shapes for Genesis
    A3 and H3 Shapes for Genesis
    Stephanie 3 and FREAK Shapes for Genesis
    Victoria 4 for Genesis 2 Female
    Michael 4 for Genesis 2 Male
    Generation 4 Legacy Shapes for Genesis 2 Female(s)
    Generation 4 Legacy Shapes for Genesis 2 Male(s)
    Generation 5 Legacy Shapes for Genesis 2 Male(s)
    Generation 5 Legacy Shapes for Genesis 2 Female(s)
    Thank you!
    dbb
    If I buy -
    Will I still need -
    Thank you!
    dbb
    Direct from the description for Generation 4 Legacy Shapes, (both G2F and G2M) "*Note: This set contains only head and body shapes. It does not include UVs for skin textures or AutoFit clones for clothing." So yes you would need Victoria 4 for Genesis 2 Female and Michael 4 for Genesis 2 Male for the Auto-Fit clones and UVs.
    Thank you!! I guess I'll be digging into my pockets deeper this month!
    dbb
    dbb
    Trust me, it's always something!!
