How do I merge M4/V4 again?
Alley RatAlley Rat Posts: 406
I seem to remember there being a way to make M4 into a morph for V4, and being able to use M4's textures on the resulting mesh. I don't remember if this would let me use M4's clothing on the resulting mesh, but I can model my own if need be. What I am trying to do is to be able to use my M4 characters with V4's 4K LOD mesh for Decimator/Poser Pro Game Dev/game testing. Am I better off just loading up the Figure Mixer in DS3A, using V4 as the base and loading M4, then exporting the 4K LOD with the M4/H4/F4 morph applied? Please help! :D
Thank you.
    edited August 2014
    DS allows you switch UV's on the fly. There is M4 Enhanced/Mina
    http://www.daz3d.com/m4-enhanced-mina-for-m4
    This product has a V4 injection comparability and accepts V4 textures. The V4 compatible version is a separate obj and cr2. It does not use the standard V4.
    I'm not certain outside of figure mixer or using a product like GenX, you can simply inject the M4 morphs into the V4 base. Could be wrong.
    Post edited by icprncss on
    edited August 2014
    You can literally morph any Generation 4 figure into any other generation 4 figure because they share the same unimesh.
    Load Michael - > Export as OBJ
    Delete Michael
    Load Victoria - > Morph Loader Pro
    Choose the Michael OBJ and call it something memorable like M4 Morph
    Enjoy your new morph
    This works for any of the Gen 4 figures, including K4, though K4 needs some reworking due to the scale differences.
    Post edited by Herald of Fire on
  • Alley RatAlley Rat Posts: 406
    THANK YOU! :D That worked perfectly.
    Delete Michael
    This works for any of the major figures, including K4, though K4 needs some reworking due to the scale differences.
    M4 has his own LOD already, if you don't have them you may want to re-download his files so you are up to date.
    Thanks! :D I did just that.. I had been using the old installers because I wasn't sure how to "initialize" M4 when installing from a zip file. I did redownload and get the LODs. All is working now.
